NiteWatcher
May 12, 2021Guide
Router Keeps Going Offline Model - RAXE500 — Nighthawk AX12 12-Stream AXE11000 Tri-Band WiFi Router
In last day or two... my brand new Router RAXE500 — Nighthawk AX12 12-Stream AXE11000 Tri-Band WiFi Router keeps going offline ... It is not ISP ... with that I have intermitent issues ...
Christian_R
Jun 03, 2021NETGEAR Employee Retired
Hello,
If you're still experiencing issues, please send me a private message with your email address and router serial number.
Thanks,
Christian
Minu
Jun 04, 2021Aspirant
No Resolution yet from Netgear. The support team has to call me back to do further troubleshooting but no call since last 1 week. Very frustrated with this product.
- Christian_RJun 07, 2021NETGEAR Employee Retired
Hi Minu & NiteWatcher,
We recently released FW v1.0.5.62 for the RAXE500. I would recommend updating to this firmware version.
https://kb.netgear.com/000063717/RAXE500-Firmware-Version-1-0-5-62
Looking forward to your next update!
Christian
- NiteWatcherJun 07, 2021Guide
I have already updated when it came out ... still going offline today... unfortunately...
Christian_R wrote:Hi Minu & NiteWatcher,
Christian
- plemansJun 07, 2021Guru - Experienced User
NiteWatcher After the update, did you try a factory reset?
The RAXE is getting updated drivers even from broadcom.
Always worth a chance when even the underlying drivers that's in the firmware is changing.
- Christian_RJun 14, 2021NETGEAR Employee Retired
Hello NiteWatcher,
I'd like to check in and see if you were able to perform a factory reset as Plemans suggested.
Christian
- Christian_RJun 16, 2021NETGEAR Employee Retired
Hello Joao,
Thanks for reaching out to me and providing your feedback. Our engineering team is aware of the reports regarding Armor on the RAXE500. I'm glad to hear that you're working with our support team and I would recommend that you please continue to work with our support team.
Christian
- joaosJun 16, 2021Tutor
Actually, I didn't open a case... yet :) I just wanted to share this, because it is an unexpected problem that may let many RAXE500 owners, like myself, frustrated. It is good to know what the cause for the problem may be and that there is light in end of the tunnel!
Christian_R wrote:Hello Joao,
Christian
- Christian_RJun 17, 2021NETGEAR Employee Retired
Hello joaos,
Ahh ok, got it! I have sent you a private message. Please respond at your earliest convenience.
Thanks,
Christian
