NiteWatcher
May 12, 2021Guide
Router Keeps Going Offline Model - RAXE500 — Nighthawk AX12 12-Stream AXE11000 Tri-Band WiFi Router
In last day or two... my brand new Router RAXE500 — Nighthawk AX12 12-Stream AXE11000 Tri-Band WiFi Router keeps going offline ... It is not ISP ... with that I have intermitent issues ...
Christian_R
Jun 07, 2021NETGEAR Employee Retired
Hi Minu & NiteWatcher,
We recently released FW v1.0.5.62 for the RAXE500. I would recommend updating to this firmware version.
https://kb.netgear.com/000063717/RAXE500-Firmware-Version-1-0-5-62
Looking forward to your next update!
Christian
NiteWatcher
Jun 07, 2021Guide
I have already updated when it came out ... still going offline today... unfortunately...
Christian_R wrote:Hi Minu & NiteWatcher,
Christian
- plemansJun 07, 2021Guru - Experienced User
NiteWatcher After the update, did you try a factory reset?
The RAXE is getting updated drivers even from broadcom.
Always worth a chance when even the underlying drivers that's in the firmware is changing.
- Christian_RJun 14, 2021NETGEAR Employee Retired
Hello NiteWatcher,
I'd like to check in and see if you were able to perform a factory reset as Plemans suggested.
Christian
