NiteWatcher
May 12, 2021Guide
Router Keeps Going Offline Model - RAXE500 — Nighthawk AX12 12-Stream AXE11000 Tri-Band WiFi Router
In last day or two... my brand new Router RAXE500 — Nighthawk AX12 12-Stream AXE11000 Tri-Band WiFi Router keeps going offline ... It is not ISP ... with that I have intermitent issues ...
Christian_R
Jun 16, 2021NETGEAR Employee Retired
Hello Joao,
Thanks for reaching out to me and providing your feedback. Our engineering team is aware of the reports regarding Armor on the RAXE500. I'm glad to hear that you're working with our support team and I would recommend that you please continue to work with our support team.
Christian
joaos
Jun 16, 2021Tutor
Actually, I didn't open a case... yet :) I just wanted to share this, because it is an unexpected problem that may let many RAXE500 owners, like myself, frustrated. It is good to know what the cause for the problem may be and that there is light in end of the tunnel!
Christian_R wrote:Hello Joao,
Christian
- Christian_RJun 17, 2021NETGEAR Employee Retired
Hello joaos,
Ahh ok, got it! I have sent you a private message. Please respond at your earliest convenience.
Thanks,
Christian
