JoseMaka
Mar 11, 2025Aspirant
Router keeps rebooting
Router keeps Factory resetting itself whenever rebooted. There's a new firmware and everytime I try to update it, it will get to the part of rebooting and then factory resets itself and needs to be se...
Mar 12, 2025Guru - Experienced User
You have the RS700?
What firmware version are you on right now?
And then how are you updating? (as michaelkenward says).
Thats key to. A manual method is best if you're having issues.
JoseMaka
Mar 12, 2025Aspirant
I'm updating via the nighthawk app and tried through the web browser also. It's running v1.0.7.86 it's saying the newest is v1.0.7.96. It resets itself everytime it reboots and for some reason at 3am also
- FURRYe38Mar 12, 2025Guru - Experienced User
I recommend you make contact with NG support and ask about RMA options.
There's been a rash of some of these routers not accepting a FW update and persisting.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
