amonynuts
Jan 23, 2022Apprentice
Router log filled with repeated DHCP assignments
Nighthawk Router RAX45-100NAS AX4300 AX6, Firmware 1.0.5.106_2.0.70 Is there a way to disable DHCP logging without disabling logging of security events? With lots of devices on my WiFi network g...
Jan 24, 2022Guru - Experienced User
How many devices do you have connected?
Look under Admin/Logs for items to un-select for logging. I recommend unchecking items that your not monitoring.
