ThomasKarp
Sep 13, 2024Tutor
Router Nighthawk RAX 50 v2 Access Denied Message
RAX50 v2 modem I am trying to access my router to edit some settings but it keeps on giving me the "Access Denied" message. I was able to contact support about a week ago and they advised to dis...
- Sep 14, 2024
So , I hope this helps someone else out there.
I've downgraded my firmware to V1.1.3.18_2.1.14 and now I don't have the "Access Denied" problem anymore.
(while connected to the interwebs, modem, you know)
Hey NETGEAR stuff, can you please make under firmware update and solve this issue ?
Pretty please with cherry on top ?
I am a big fan of latest firmware and software updates, but this was not a good move.
I don't know where the problem lies exactly, but it's definitely a NETGEAR problem.
Good luck everyone navigating Netgear marketing strategies!
ThomasKarp
Sep 13, 2024Tutor
It's a router. NOT a MODEM. Got mixed up.
Thanks for pointing it out.
Don't know how or if I can edit my post.
Sep 13, 2024Guru - Experienced User
so you're going modem/gateway---->router------>RAX50?
Again, details are key. What modem/gateway do you have and then what router is the RAX50 connected to?
