ThomasKarp
Sep 13, 2024Tutor
Router Nighthawk RAX 50 v2 Access Denied Message
RAX50 v2 modem I am trying to access my router to edit some settings but it keeps on giving me the "Access Denied" message. I was able to contact support about a week ago and they advised to dis...
- Sep 14, 2024
So , I hope this helps someone else out there.
I've downgraded my firmware to V1.1.3.18_2.1.14 and now I don't have the "Access Denied" problem anymore.
(while connected to the interwebs, modem, you know)
Hey NETGEAR stuff, can you please make under firmware update and solve this issue ?
Pretty please with cherry on top ?
I am a big fan of latest firmware and software updates, but this was not a good move.
I don't know where the problem lies exactly, but it's definitely a NETGEAR problem.
Good luck everyone navigating Netgear marketing strategies!
Sep 13, 2024Guru - Experienced User
What modem is it? You still haven't said. You've said its from telus fibre optic. And that its basically a switch.
Which usually implies it has its own routing features built into it.
And while you might "only be using it for access", unless you actually disable those routing features or setup the RAX properly, it puts you in a double NAT and can create issues.
ThomasKarp
Sep 13, 2024Tutor
Sorry if I seem to be skipping on information or maybe not reading your messages.
The modem has been set as a bridge, doesn't do anything but providing internet.
A 10Gb connection on the modem is set as a BRIDGE to RAX 50 v2.
Please see attached images.
