TjckTock's avatar
TjckTock
router not seeing devices on upstream router
I replaced a failing ancient Cisco wifi in the shed with a RAXE500 Wifi router.  It is connected via ethernet to another router in the home which also has a NAS connected to it.  Previously, the old ...
  • TjckTock's avatar
    Oct 08, 2023
    Thank you for your responses.  The solution that worked for me was to change the router to AP mode (ADVANCED-->Advanced Setup-->Wireless AP).  Just an FYI for anyone else landing here, although it is called "Wireless AP mode" it does appear, in fact, to apply to the wired connections as well.
