Redtulips7
Mar 11, 2023Luminary
Router Password Reset>Your Device is disabled, Please try again in 5 minutes.
I am keep getting same warning about Router Password reset? Factort reset didn't help, I have tried .96 and .94 Firmware, same warning when I try to Log in. By the way This is new Router RAXE500
- Mar 27, 2023
Fix was uninstall Network Adapter from Device Manager(Desktop) as well as remove Driver package from Add/Remove Program then restart Computer then reinstall Network Driver. Make sure you Power Cycle Modem/ONT(Unplug for 5 Minutes) prior to install new Router, and don't put any special Characters in Router Log in Password.
Redtulips7
Also I didn't what FW Router came with but it update to .86 FW which I didn't have any issue!!! after manually update to latest FW .96 warning started to pop up.
- Redtulips7Mar 11, 2023Luminary
This fuc$$$ Router is going back to hell
I went back to FW .86 where no issue at all
So it seems like I am the only one facing this weird problem??????????
