Redtulips7's avatar
Redtulips7
Luminary
Mar 11, 2023
Router Password Reset>Your Device is disabled, Please try again in 5 minutes.
I am keep getting same warning about Router Password reset? Factort reset didn't help, I have tried .96 and .94 Firmware, same warning when I try to Log in. By the way This is new Router RAXE500
  • Redtulips7's avatar
    Redtulips7
    Mar 27, 2023
    Fix was uninstall Network Adapter from Device Manager(Desktop) as well as remove Driver package from Add/Remove Program then restart Computer then reinstall Network Driver. Make sure you Power Cycle Modem/ONT(Unplug for 5 Minutes)  prior to install new Router, and don't put any special Characters in Router Log in Password.
