Redtulips7
Mar 11, 2023Luminary
Router Password Reset>Your Device is disabled, Please try again in 5 minutes.
I am keep getting same warning about Router Password reset? Factort reset didn't help, I have tried .96 and .94 Firmware, same warning when I try to Log in. By the way This is new Router RAXE500
- Mar 27, 2023
Fix was uninstall Network Adapter from Device Manager(Desktop) as well as remove Driver package from Add/Remove Program then restart Computer then reinstall Network Driver. Make sure you Power Cycle Modem/ONT(Unplug for 5 Minutes) prior to install new Router, and don't put any special Characters in Router Log in Password.
Redtulips7
This fuc$$$ Router is going back to hell
Redtulips7
I went back to FW .86 where no issue at all
- Redtulips7Mar 11, 2023Luminary
So it seems like I am the only one facing this weird problem??????????
- michaelkenwardMar 12, 2023Guru - Experienced User
Maybe no one else understands the problem, what you are doing and where things go wrong.
Your details are a bit sketchy.
Among the many gaps in the information is the modem/gateway/ONT that sits in front of your router, where you see this error, and lots of other variables.
- Redtulips7Mar 12, 2023Luminary
Picture above shown error or Password Reset genearate from Netgear Log in Screen!!! or you were failing to see it????????? ONT don't give you error or is it? This thing happened after I set up the Router AX11000 within a minutes in the Router Log in Screen!!! I have had seven NG Routers in last twenty years and never seen it!!never!
It does not do with FW .86 but anything after, I am always reset ONT before setting up the Router, password reset was generating from NG Log in Screen even after hard reset?
To resolve this issue I have had done last night to uninsall Network Adapter(intel 1219-v)along with Driver,reboot then reinstall Driver 28.0 after that error or password reset warning STOP. I have had installed new FW .96
and no issue.
