AJ290
Jun 15, 2019Aspirant
Router Placement
I'm wondering how placement of the router affects signal strength. Specifically with the RAX40. My current modem/router combo is a lease from Xfinity and sits on the desk next to me.
Upgrading to a new modem and router has me thinking about where best to place the router. The modem will be seated next to me because the cable comes into my office and my laptop is wired in. My office is pretty much the center of the house. But I'd like to get the router up on top of the computer hutch if I can. Running an ethernet cable from modem to router isn't a problem. But what about the power cord? How long is the supplied cord with the RAX40? If needed can I use an extension cord?
AJ290 wrote:
The CM1100 modem has two ethernet ports. One port will be wired directly to the router, (other port remains unused?). Then I run a cable from the router to my laptop, correct?Correct.
AJ290 wrote:
what is the advantage of this vs a direct cable from modem to laptop?
Modem to laptop won't work. (See above.) There is no router in the modem.
AJ290 wrote:
And if the RAX40 doesn't support ethernet port aggregation, why set it up as if it does?
You can't set it up "as if it does". You just have a redundant port on the modem.
AJ290 wrote:
Is it worth the bump in price to go with the RAX80?
That's your call.
How fast is your Internet speed? Do you need faster access? Do you really want to "double maximum wired speeds"?
Port aggregation is one of those features loved by users who just like to boast about the speed of their systems, regardless of whether they need that speed.
Netgear's power adapters are usually the same length, about six feet.
An extension for the mains adapter is no problem.
The usual advice is to put the wifi source high up in the room and as central as possible. Sounds like you have that covered.
Remember, if you have a separate modem and router, the laptop will have to be wired into the router, not the modem.
