GBAX
Mar 30, 2020Aspirant
Router Purchase
I am looking for a recomendation. Here is what I have, a two story house with a structured wire cabnet on second floor housing my R7000. I have two data runs to a first floor office but need more h...
additude
Mar 30, 2020Virtuoso
"I have two data runs to a first floor office but need more hard wire connections in that room."
If that means that you already have ETH cables run to the office then just put a switch on one of them and save yourself a lot of cash and headachs.
- GBAXApr 02, 2020Aspirant
Thank you all for the info.
additude wrote:"I have two data runs to a first floor office but need more hard wire connections in that room."
- additudeApr 02, 2020Virtuoso
You will only need an Unmanaged Gigabit switch, less than $50 bucks....
Oh, and BTW ...
Only plug 1 (one) of those two cables you have into it.
One cable goes into it and other equipment goes into it.
On one of my setups. I use a TEW-7500AP as a wireless bridge that I have had no problems with....
If you want to go that route...
