xxtensazenxx
Mar 09, 2022Guide
Router (RAX120v2 ) keeps randomly rebooting
Router is the RAX120v2 keeps randomly rebooting. I'm just doing normal browsing and my interent says its dead (hardwired) then I check wifi and its not even showing my SSID. I go and look at the rout...
Mar 15, 2022Guru - Experienced User
Has a factory reset been performed and setup from scratch?
Was FW already up to date when you go it or did you update FW? If you updated FW, how was FW updated on the router? Nighthawk app or manually thru the web page on the router?
xxtensazenxx wrote:
Router is the RAX120v2 keeps randomly rebooting. I'm just doing normal browsing and my interent says its dead (hardwired) then I check wifi and its not even showing my SSID. I go and look at the router and it appears it fully turned itself off and all the lights are starting to turn on again, as if its a fresh boot. The router is not getting hot or anything either. I've only had it for 4 months and it cost $400 something dollers so its rediciloous this is happening. My old linksys routeter never crashed a single time.
1 - The modem is connected stright to my internet (I have FIOS and it just runs an ethernet cord from the fios outlet. No modem inbetween)
Firmware Version V1.2.3.28
