Docjed60
Nov 14, 2021Aspirant
Router Reset
I have been having trouble with this router resetting continuously and it is new. I called support and they claim that my log showing A few dos attacks was the reason for it resetting. I believe that ...
Razor512
Nov 14, 2021Prodigy
By reset, can you provide more detail?
Is it simply powercycling itself or is it factory resetting itself to the default configuration?
While I have not tried the RAX120 before, the other RAX routers that I have tried, when doing various DOS attacks, from a system connected to the WAN port,I was unable to get it cause any stability issues. Furthermore, nothing was able to even cause even 1% additional CPU usage (and that is on their older and far slower models), while there are nearly limitness possible attacks, if remote access is disabled, it doesn't look like much or anything could impact how the router behaves on the LAN side. If it keeps restarting, (power cycling), then I would suspect either the power adapter or a hardware issue. Especially considering that a power supply can supply the correct voltage but too much line ripple that exceeds what the input filtering can handle, will cause stability issues, same if any subsequent rails that the motherboard generates.
On the LAN side, it is possible for some devices to cause random reboots if they are compromised and are effectively running through an exploit tookit in an attempt to compromise therouter, though that is rare, and you would notice issues with other routers as well.
PS, when you are under an actual DOS attack, the logs will be flooded with entries.
- Docjed60Nov 14, 2021AspirantWhen the router loses connection it does A complete reset losing everything till it restarts. The log only shows one attack when the router goes out also that is A problem. I had to take it completely offline and put my older router back in just to be able to watch A movie and have not had any problems with it. I did not buy A router to be A beta tester, I want A working product
- Razor512Nov 15, 2021Prodigy
If possible, manually installing the latest firmware could help rule out any corruption, if it still happens, it is likely a manufacturing defect with the product. While they are very rare, all brands will encounter some manufacturing defects.
In cases like that, it would be best to do an RMA and get a replacement.
Beta testing is not really for hardware issues, as those are handled during the R&D and QA phase.
