Docjed60
Nov 14, 2021Aspirant
Router Reset
I have been having trouble with this router resetting continuously and it is new. I called support and they claim that my log showing A few dos attacks was the reason for it resetting. I believe that ...
Nov 15, 2021Guru - Experienced User
A couple things.
1. What firmware is on the router?
2. What modem/gateway is it connected to?
3. You don't have to capitalize "A". I'm not sure why you are but it kind of throws the reading off
4. You said when its happening, the router reboots? It doesn't just loose connection?
5. have you noticed if it happens mainly when you're on wifi? or does it happen when using wired devices as well?
