wcrftsmn
Aug 06, 2023Aspirant
Router Restarting every 2 hours.
Hello, so I have been having issues for several months with my router restarting randomly. After looking at the log, perhaps it isn't so randomly. It seems to be restarting at exactly 2 hours. Any id...
microchip8
Aug 06, 2023Master
Are you sure it's restarting? Because after a restart you should see something like "initializing firmware..." in the logs. What you posted looks to me that it's just testing the Internet connection and reporting whether it's up or down.
wcrftsmn
Aug 07, 2023Aspirant
You are probably right, however, our router still restarts intermittently, and I am not sure the logs actually show that then. Support has decided to send a replacement after lots of troubleshooting.
Thanks to everyone for your help.
- FURRYe38Aug 08, 2023Guru - Experienced User
What model router is this? RAX120? If so, what is the first 3 characters of the router serial number?
