TotalEnigma
Feb 08, 2021Guide
Router Speed Tests Very Slow
I just purchased a RAX200 router and when I perform a speed test either in QOS or in the NightHawk phone app, my downloads speeds have trouble getting out of the 400Mbps space. This is very slow comp...
Feb 08, 2021Guru - Experienced User
Reason why is the built in speedtest doesn't always pick the best test server to test off. So speeds >500mbps tend to be inaccurate for the built in test server.
If you're other devices are working properly, getting proper speeds, then I wouldn't worry about it.
