Sergeroy65
Dec 08, 2020Aspirant
Router stop emetting wifi suddently, need to unplug router to restart signal
Need your adivse, router is new. Several times per day the router stop emetting wifi signals, both lights for 2,4Ghz and 5 Ghz still show steady green, but there is no wifi. All lights are green bu...
abelak
Dec 09, 2020Guide
If your model number is rax40 (not rax40v2) and firmware is 1.0.3.80 you may have to update to latest firmware after physically resetting your device. Lot of people experiencing issues with this router.
- Sergeroy65Dec 09, 2020Aspirant
Thanks for the info, I will have to verify the software version. Is there is a link to a procedure to verify the version and update a new one?
thanks
Serge
- abelakDec 09, 2020Guidehttp://www.downloads.netgear.com/files/GDC/RAX40/RAX40_UM_EN.pdf
Page 90 for firmware.
Check at the bottom of the router for model name.
