VibratingTurtle
Mar 24, 2021Aspirant
Router unable to connect to internet (RAX 35)
I have not had internet for three days already. (Note: I have had this router for maybe a year now). I have tried every combination of unplug the modem and router to no avail. I called my internet pro...
antinode
Mar 26, 2021Guru
> [...] (RAX 35)
RAX35[v1] or RAX35v2? Look for "Model" on the product label.
> [...] Using the Netgear app is also completely useless. [...]
Not a useful description of what you did, or what happened when you
did it, but, if you don't like the app, then why not use a web browser?
> [...] Every solution keeps telling me to use it when I can't. [...]
What does "Every solution" mean to you?
> [...] I need internet connection to use the router [...]
Says who? Define "use the router"? No Internet connection is needed
to _configure_ the router.
> [...] The internet light on the router is orange. [...]
What about all the other LEDs?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Beyond the
basic set-up instructions (including "Use a web browser to access the
router"), look for the LED descriptions and "Troubleshoot".
> Why in the salty [...]
Grow up? Is that kind of stupidity physically painful to you, too,
or only to your interlocutors?
