AlexTH
Dec 31, 2020Aspirant
Router Update
Got an email about a firware update, 1.0.2.136 And when I went to my router, it also said firmware update available. When I clicked "check for upgrade", it connected to server, then replied "no upd...
Dec 31, 2020Guru - Experienced User
You can always update manually. Its the way I prefer to do it. I also make sure to only update over a hardwired connection. When we see corrupt firmware issues on here it tends to be when done over wifi or using the app.
- AlexTHDec 31, 2020Aspirant
I was wired- on the desktop, less than 3 feet from the router
