devturtle
May 09, 2020Follower
router won't boot after firmware update (rax45 from costco)
hi, so we just bought a new nighthawk ax6 from costco, and i tried to update the firmware, and it just... wouldn't boot. i'm wondering if the firmware got corrupted. resetting wouldn't work, either....
May 10, 2020Guru - Experienced User
sounds like you're right on it getting corrupted. In the future, I recommend updating firmware over a hardwired connection. don't do it over wireless or the app. its usually where we see the most problems.
you can try recoving it via tftp
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
make sure to enable tftp within windows
https://www.thewindowsclub.com/enable-tftp-windows-10
and watching a video is helpful.
https://www.youtube.com/watch?v=R9DLrLQrpaw
If it doesn't work, I'd just exchange it at costco as they have a very generous return/exchange policy and its probably faster than going through warranty.
