Mjackson84
Jan 05, 2022Aspirant
Router wont connect to internet rax20
Hi, I am having troubles connecting my RAX20 to the internet. The service providers answer is to use theres.... FYI i have there router currently running so i no the connection is there. ht...
Mjackson84
Jan 06, 2022Aspirant
Thanks for the infomation, the ISP modem is as follows
https://help.slingshot.co.nz/hc/en-us/articles/360021092293-Modem-Setup-Guides
Netgear firmware 1.0.4.100
I was hoping to remove the netcom modem and only use nighthawk, but maybe ill use it as an AP for wifi
Im currently at work but ill try you advise later tonight, thanks again
cheers, Matt
Jan 06, 2022Guru - Experienced User
Contact your ISP to see if that some that is supported. They should know all about there modems and such and if something can be swapped out. There maybe some configuration requirements.
