jmlkuehn
Mar 15, 2021Follower
routerlogin.net data breach google password message 20 minutes ago
Just received google password manager data breach for admin login for routerlogin.net. I am out of state on vacation anbd not sure what to do - HELP! John.
schumaku
Mar 15, 2021Guru - Experienced User
Not much to worry, as routerlogin.net does point to your router LAN IP, and you might have a dead simple or common password for your router local admin user. Unless you have exposed the real Remote Management (not the app based anywhere Access) there is nothing to bother.
