Richard1864
Aug 07, 2019Luminary
Routerlogin.net digital certificate expired
Just discovered that the digital certificate for routerlogin.net has expired; it expired on August 2, 2019, and apparently no one at Netgear noticed it or fixed it yet that is why browsers like Chro...
shamrockshake
Sep 23, 2019Tutor
I purchased the RAX120 Nighthawk on August 8, 2019. I have not been able to login to www.routerlogin.net yet! I keep getting: Routerlogin.net digital certificate expired. This is VERY upsetting. I installed the Nighthawk app on my Samsung phone and it will not accept the network key code. So how am I supposed to update or view anything if nothing works?
Richard1864
Sep 23, 2019Luminary
FCC has confirmed all supported Netgear routers, consumer and business, are affected by this expired certificate, that the issue has been raised with Netgear, and they don’t know if Netgear will ever fix it. The FCC claps confirmed this expired certificate affects accessing https websites and apps, and prevents even simple router maintenance as administrators can no longer login to the routers. The FCC no longer recommends purchasing Netgear routers because of this outstanding critical issue.
It would be really nice if Netgear would finally actually REPLACE the expired certificate. Even the FCC says this should have been done within 12 HOURS of it first being reported and emergency firmware updates pushed out to all supported routers within 24 hours of first report.
