Richard1864
Aug 07, 2019Luminary
Routerlogin.net digital certificate expired
Just discovered that the digital certificate for routerlogin.net has expired; it expired on August 2, 2019, and apparently no one at Netgear noticed it or fixed it yet that is why browsers like Chro...
BrianG_Simi
Oct 02, 2019Star
The certificate was valid from 8/2/2016 on 8/2/2019.
It's now 10/2/2019.
Not a good look; makes you wonder what other security NETGEAR doesn't take seriously.
Please fix ASAP.
Using Orbi RBR50 - Router Firmware Version V2.3.5.30
davidcheok
Oct 13, 2019Apprentice
Any update on this issue? Is there a workaround we can do that doesnt depend on netgear?
- shamrockshakeNov 04, 2019Tutor
I wish I could say I have a new router, but I couldn't return mine, so I am stuck with the Nighthawk--still unable to login with admin and password [mine] on my desktop computer. I have tried every way possible. I ended up downloading the netgear app [as per nighthawk suggestion on paperwork] and I can see some information, but it NOTHING like being able to login to router and see it all. The informatin on the app is not even comparable to what I used to be able to monitor from my desktop. As far as I can tell that certificate still has not been renewed or Netgear has taken steps to make sure we only use the phone app and receive less information. I can't imagine what else it could be that some of us cannot login from a computer to see ALL router information. Maybe someone else in this forum has some newer information.
- Richard1864Nov 04, 2019LuminaryFCC confirms digital certificate NOT replaced, no longer recommend using ANY Netgear routers or Extenders as expired certificate prevents all major router functions from operating properly, even firewalls confirmed as disabled despite UI indicators.
How can businesses keep selling these as safe, workable routers if the"FCC confirms digital certificate NOT replaced, no longer recommend using ANY Netgear routers or Extenders as expired certificate prevents all major router functions from operating properly, even firewalls confirmed as disabled despite UI indicators?" Anyway to verify if firewall is REALLY disabled? Something doesn't seem right.
