Richard1864
Aug 07, 2019Luminary
Routerlogin.net digital certificate expired
Just discovered that the digital certificate for routerlogin.net has expired; it expired on August 2, 2019, and apparently no one at Netgear noticed it or fixed it yet that is why browsers like Chro...
shamrockshake
Nov 04, 2019Tutor
How can businesses keep selling these as safe, workable routers if the"FCC confirms digital certificate NOT replaced, no longer recommend using ANY Netgear routers or Extenders as expired certificate prevents all major router functions from operating properly, even firewalls confirmed as disabled despite UI indicators?" Anyway to verify if firewall is REALLY disabled? Something doesn't seem right.
shamrockshake
Nov 04, 2019Tutor
Update: While I did not get a response to the certificate not renewed by Netgear, I did speak with a technician today and after our long conversation I was able to login to my router. At first I had to use another browser, other than Chrome. Because I couldn't login before I was not able to get the current firmware update of 1.0.1.100 for my router. She said that update fixed a problem of not being able to log in--cause being the 1.0.1.90 firmware problem [no details]. After a long while of security hoops between my antivirus and trying different browsers and different kinds of computers, on my desktop [using Windows], I was able to go to the Netgear support page, locate my router, download the current firmware to my computer [which came in a zip file]. I removed the .img to my desktop, went back to my Google browser, entered the 192..... IP address, logged in, and via advanced, admin, firmware browse and upload I was able to login on Chrome like I used to do. I was able to view all the files at the router site. So far I can still login to the router. I plan to check on the certification when I get back with support. Hope this helps someone.
- trialcriticNov 05, 2019Guide
I can confirm that the login works for me now. I do not get the digital certificate expired message.
- BrianG_SimiNov 27, 2019Star
The cert is no longer invalid due to being expired; now, it's not valid because it's self-signed. Not really an improvement on my end. At least there was a change - just laterally instead of forward.
