Richard1864
Aug 07, 2019Luminary
Routerlogin.net digital certificate expired
Just discovered that the digital certificate for routerlogin.net has expired; it expired on August 2, 2019, and apparently no one at Netgear noticed it or fixed it yet that is why browsers like Chro...
Squeeky
Mar 01, 2020Initiate
Just bought and Orbi and updated it to the latest release. Finally found a mesh router that works well but to my surpirse the certificate to routerlogin.net is STILL expired. I keep getting errors on my phone from my email client. Now it has been 7 months (2019-08-02) since this occured and Netgear appears to have done nothing.
Is this becuase:
1. Other prorites
2. Too cheap to extend the cert
3. Don't care
None of these options is satisfactory to me. I might be returning this unless somebody from Netgear can comment on why this has taken so long and what the long term solution is.
- Richard1864Mar 01, 2020LuminaryI suspect #3 Don’t care. The quality of Netgear’s routers and their firmware have gone downhill quite quickly since this digital certificate mess started. I dumped my Netgear router less than 2 weeks after it started and NO ONE at the company bothered to even to discuss the issue.
7 months later and still NOT fixed. Makes me wonder what other problems they can’t be bothered to fix. I won’t come back to this epic fail company.- AltsaiMar 02, 2020NETGEAR Expert
RAX120?
- schumakuMar 02, 2020Guru - Experienced User
Squeeky wrote:Just bought and Orbi and updated it to the latest release. Finally found a mesh router that works well but to my surpirse the certificate to routerlogin.net is STILL expired. I keep getting errors on my phone from my email client. Now it has been 7 months (2019-08-02) since this occured and Netgear appears to have done nothing.
Many other router models have got self-signed certificates now. Well possible the more than non-existing quality control at the ODM has simply failed again.
Squeeky wrote:None of these options is satisfactory to me. I might be returning this unless somebody from Netgear can comment on why this has taken so long and what the long term solution is.
Altsai keen to hear what the long term solution will be for all Netgear devices, too. Self-signed - this is what almost all other newer Netger router have got again because of some "security" specialists raised security reports about the shared private key of the former Entrust signed certs - can't be the answer, too. FWIW there can be two phases: One is the factory preset (here an ad-hoc and installation time self-signed cert is fine), the other is the every day solution once installed.
