Scott302
Mar 13, 2021Follower
run 2.4GB for Feit bulbs
I just unstalled the Nighthawk Mesh. I cannot get my Feit WiFi bulbs to locate the router. They need to operate on 2.4GH only. The bulbs are in the same room as the router and in line of sight. An...
antinode
Mar 13, 2021Guru
> I just unstalled the Nighthawk Mesh. [...]
Has it a model number? Look for "Model" on the product label.
> [...] Any ideas on how to get the bulbs to see the 2.4 side of the
> router??
If the gizmos operate on 2.4GHz only, then there's no problem getting
them not to see the other band. The usual problem is in getting the
device with the app to use the 2.4GHz band, which seems to be a
requirement during the gizmo set-up procedure (but not for normal
operation, later), for reasons which I don't understand.
