Steve12286
Oct 21, 2021Aspirant
Running nighthawk M1 off iPhone data
hi all Is it possible to connect my iPhone directly to a Nighthawk M1 via cable or otherwise, so that I can use my unlimited mobile data for other devices, I know I can just use my iPhone as a mobi...
Oct 22, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
Steve12286
Oct 22, 2021Aspirant
Thank you, not being the technical type, I guess that’s a yes 👍
