mual
Nov 30, 2020Tutor
RX4300 router sudden block devices
I have this router for 4 months and twice I had some of my device had been drop from connection while others are still on. Both times I had to power cycled it to get thing works again. Any idea, why?...
Nov 30, 2020Guru - Experienced User
AX4300 is a speed not a model. (you put RX4300 which isn't either)
What model do you have?
What firmware is on it?
What modem/gateway is it connected to?
When the devices drop, do they say "connected, no internet", do they disconnect from the wifi and won't reconnect?
What happens exactly?
