anakat
Oct 24, 2020Follower
RXA35 - factory reset
My Router has by itself suddenly reset it self to factory settings. It shows NETGEARXX in the WIFI list.
But now when I am using Nighthawk APP to add a new device, it is not accepting the default password = password.
I have reset the router again and again to factory settings. But it does not get reset to default password and I am not able to set the new router again.
Recovery is not an option as i am willing to reset it to factory but the default password is not working
Any help will be really appreciated.
1 Reply
When you reset, did you push and hold reset for 7-15 seconds until the lights flashed?
default login: admin
default password: password
all lower case
you can also try a different browser/pc.
