Maxgur's avatar
Maxgur
Guide
Jun 22, 2020
Samsung s20 does not connect
Samsung S20 does not connect and sometimes WIFI connection with devices disappears.
Rebooting the device helps. But this is not normal for the device at such a cost! Please fix the problem in the following firmware
    It seems just fine on my S20+.  My S20+ is the Unlocked US version, with Software version: G986U1UES1ATFB (Android 10 w/ July 1 security updates), One UI version 2.1).
    Are you using WPA2 or WPA3?  Try connecting to 5.0Ghz, works really great here.
