花开
Apr 20, 2021Follower
Satellites MS60 can't connect to MR60 with CH149
I bought a WiFi6 Mesh router MR60 with 2 Satellites MS60 (FW: V1.0.6.102_2.0.45). When I use default wifi settings with CH42, Mesh connection can established successfully,. But when I change MR60's 5G channel to 149 in wifi setting, my two satellites can't connect to MR60, MS60's LED is always amber. I am sure CH149 is supported in China.
1 Reply
china does support channel 149. but not channel 144 or 151 which are next to it. So when the channel width is set to wide, those channels aren't available because of channel overlap.
