jweegar
May 29, 2025Aspirant
Saving Attached Device Edits
Are attached device table edits saved into the router’s backup .cfg file? If so, are these edits restored upon a .cfg restore operation? Is there anyway to transfer/copy/send attached device ...
May 29, 2025Guru - Experienced User
I believe only saved if a IP address reservation is configured for devices.
Attached devices is a transitory status as that status checks to see if the device is online and connected. If the device disconnects then the status changes and the device will not appear in the attached devices list. Nothing to save here.
One could try saving a back up config from the model router and try restoring to same model router. Won't work between different model routers.
