McLex's avatar
McLex
Follower
Dec 30, 2020
Seamless Roaming
I brought a RAX120 & RAX50 & Mesh extender EX6250 and would like to set up a seamless roaming at my home. however i tried several times and set up, it didn't work.
My set up is Modem lan wire to RAX120, RAX 120 lan wire to RAX 50 and wireless connection EX6250 mesh extender
Anybody can help how tp set up these equipments in order to have seamless roaming. RAX 120 is located ground floor and RAX 50 is located 2nd floor. There is a cement ceiling in between and linked with stairs.
Thank you very much.
Matthew
1 Reply
  • the only device you have that is actually mesh is the EX6250.
    It can either mesh with the RAX120 or the RAX50. Not both. And neither is mesh by themselves.
    If you're wanting an actual mesh system, look at the orbi series. it supports mesh in both wired/wireless backhaul mode.
