balor98
Aug 25, 2023Follower
Seamless transition from R7800 to AXE11000?
Hi all, long time Netgear guy. I’ve had my R7800 router since 2017/2018 and it is still going relatively strong but I’ve noticed it doesn’t reach the rear room as well anymore. Still hitting 500mbps ...
microchip8
Aug 25, 2023Master
If you just replace the R7800 with the new one, and the latter uses the same subnet (192.168.1.1 or similar) and the same SSIDs for wireless, then you won't have too many issues with your devices. Most will reconnect to the new router just fine.
