balor98
Aug 25, 2023Follower
Seamless transition from R7800 to AXE11000?
Hi all, long time Netgear guy. I’ve had my R7800 router since 2017/2018 and it is still going relatively strong but I’ve noticed it doesn’t reach the rear room as well anymore. Still hitting 500mbps ...
Aug 25, 2023Guru - Experienced User
I swap routers regularly. As long as you use the same ssid/password, it should all swap over fine. Its the rare device that doesn't.
