HowardLu
Oct 24, 2020Aspirant
Security Access Control is out of control after devices over 20-30
Hi, Netgear:
I met big problem about access control when it is turned on.
I turned on access control, and checked "Block all new devices from connecting"
Block function is worked, but after 20 - 30 clients connected, I make some clients to "allowed". but it cannot be "allowed", and when I reboot device, some "ever allowed" clients change to blocked. and I also observed the access control menu is always refreshing and become slower, very hard to show this page.
When saw this symptom , I found another issues is that all buttons cannot be controled.
To fix this problem, I need to factory reset to make it recover, but when all clients are relogin, this symptom is happened again.
Please kindly fix it, I listed device info here.
| Hardware Version | R1.05 |
| Firmware Version | V1.0.3.80_1.0.1 |
| GUI Language Version | V1.0.3.80_1.0.0.14 |
Thanks,
Howard.
- Christian_RNETGEAR Employee Retired
Hi Howard,
May you revert to the previous firmware version and let us know if your issue persists.
https://kb.netgear.com/000061392/RAX40-Firmware-Version-1-0-3-64
Christian
- HowardLuAspirant
Hi, Christian:
Thanks a lot,
But when I roll back to V1.0.3.64, WIFI function become unstable, it continued to ON and OFF automaticaly.
Need to use latest firmware to make WIFI worked.
BR,
Howard.
