FrankSJr
Feb 22, 2026Follower
Security Email
I am having a problem setting up Security email to my icloud account. I have followed all the directions I can find but still get failure to send messages in the message log. Setting i have used are: smpt.mail.icloud.com; outgoing port 587; also tries ports 25 and 465. Anyone have any ideas. Thanks. Frank
1 Reply
Per https://support.apple.com/en-us/102525
- Server name: smtp.mail.me.com
- SSL Required: Yes
- If you see an error message when using SSL, try using TLS or STARTTLS instead.
- Port: 587
- SMTP Authentication Required: Yes
- Username: Your full iCloud Mail email address (for example, johnappleseed@icloud.com, not johnappleseed).
- Password: Use the app-specific password that you generated when you set up the incoming mail server
Note the "app-specific password" bit. There is more information on that here:
- https://support.apple.com/en-us/102654
