FritzGman
Jan 23, 2021Aspirant
SECURITY HOLE BUILT-IN? (RAX35v2)
Bought this Walmart special router on sale to give WiFi 6 a try after getting an Intel AX200 card and I've had nothing but a bad experience. 1) My Netgear R6300v2 router was more stable and consis...
- Jan 23, 2021
FritzGman wrote:2) I can't find a way to turn off PORT 80 on the WAN side of the router! Seriously Netgear? Port 80 on my ISP DHCP assigned address???
Just in case - the WAN/Internet port can behave different if you are accessing the public IP from the LAN (internal) side than from outside.
antinode
Jan 23, 2021Guru
> [...] My router is exposed to the internet over port 80 AND I CAN'T
> FIND A WAY TO TURN IT OFF. [...]
Where, exactly, is the web browser where are you doing this? Some
computer/device on your LAN? Have you tried doing it _really_ from
"the WAN side of the router"?
> [...] does this look safe to anyone?
I can't (yet) see your picture. In-line images must be approved by a
moderator before others can see them. The time required varies.
Attachments have no such limitation. Of course, attachments have their
own one-per-message limitation.
