JamesterReyburg
Mar 15, 2021Star
Separating or Disabling 5Ghz and 2.4Ghz on Mesh WiFi 6 System
Nighthawk Mesh WiFi 6 System AX1800 (model number refused to type in, above) My problem feels simple, though the solution seems elusive. I have a houseful of Amazon Echo devices (along with s...
Christian_R
Mar 17, 2021NETGEAR Employee Retired
Hello JamesterReyburg,
The Nighthawk Mesh system currently does not support the feature of separating the 2.4Ghz and 5Ghz bands.
Christian
- JamesterReyburgMar 17, 2021Star
Thank you. Any ideas for Amazon Echo devices that just won't play nice? It's maddening, especially since it used to work just fine. . . Thanks again. --Jamie
- JamesterReyburgMar 21, 2021Star
I really am lost, and could use a suggestion (even if it is admitting that my Nighthawk mesh system was an expensive mistake. I've got problems with smart switches that once worked, that no longer want to. Inconsistent connections with my echo devices. The garage door set up was torture. And it all seems to be centered around the 5Ghz/2.4Ghz problem. There is NO WAY to address this with this system? Thanks for your initial answer, but what do OTHER people do in this situation? Thank you. --Jamie
