Laurent78
Oct 05, 2021Aspirant
Setting up DNS when IP is provided by ISP
My ISP do not let me the option to get a static IP adress so I have to select "IP provided by ISP" in internet V4 configuration. The issue on my RAX10 is that I cannot choose my DNS and am forced to ...
Jeronimo454
Oct 07, 2021Tutor
It doesn't matter if your ISP gives you an IP dynamically or not for you to be able to change the DNS server.
Login to your router --> the basic home page displays --> select internet --> here you should arrive to the page where you have selected to get an IP dynamically from your ISP. --> Scroll down to see "Domain Name Server (DNS) --> under "Use these DNS servers" you can enter the IP's of your preferred DNS servers.
I also have a dynamic ip address from my ISP and I do the same.
- Laurent78Oct 08, 2021AspirantAlright so it may be due to the smart parental control. It is strange to me because this field is accessible for me only when I simulate to set a static IP.
Do you also have the V1.0.5.108 software ?
