MC87
Feb 22, 2021Aspirant
Setting up Multigig 2.5 port on Nighthawk RAX 200
I have owned this modem since June 2020 and have only used the Internet Port (1Gbps). I recently purchased a new modem Arris S33 which also has a 2.5gig port. So I switched the settings on internet se...
michaelkenward
Feb 23, 2021Guru - Experienced User
This modem is? The RAX200 is a router, so it won't be that.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers
Cable Modems, Routers and DSL Modems. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
