nocinc
Sep 23, 2021Aspirant
Setting up Netgear NightHawk AX12 AX6000 RAX120 to Wirelessly Connect to Motorola DOCSIS 3.0 (Bridge
Setting up Netgear NightHawk AX12 AX6000 RAX120 to Wirelessly Connect to Motorola DOCSIS 3.0 (Bridge) I would like to just enable the NightHawk as a grange extender but it would not hurt to al...
Sep 23, 2021Guru - Experienced User
Since this model doesn't have a Repeater function, you'll not be able to wirelessy connect the RAX to your host router and use it as a repeater/extender. The RAX only supports AP or Wireless bridge mode which for Bridge mode, means the RAX becomes a wireless client to the host router and then you can ethernet connect devices to the back of the RAX.
nocinc
Sep 24, 2021Aspirant
I am not sure what you mean, you say it will not work but contradict yourself saying it will do exactly what I want. Wireless connect to my main router.
