Oldoobie
Nov 26, 2020Aspirant
Setting up new home
Hello there! I am building a new home. It is a medium sized 2 story home with a balcony on the 2nd floor. I have cable being installed. I want to install the best Netgear that is available. Should I...
Nov 26, 2020Guru - Experienced User
If its still in construction and you don't have sheetrock, I'd run some ethernet wires in the home. Its cheap to do and most builders will let you do it yourself. Easy, cheap, and will come in helpful in the future.
its tough to tell you exactly what to buy. Medium sized means different sized to different economical statuses.
The orbi's are pretty darned good though.
michaelkenward
Nov 27, 2020Guru - Experienced User
I second the idea of doing Ethernet. Gives you better options.
