NMLiz
Oct 14, 2022Guide
Setting up RAX38v2 as an access point
I am trying to set up my Nighthawk RAX38v2 as an access point. I was using it as my main router, but the upload bufferbloat was killing our network, so I bought an IQRouterv3, which is installed afte...
Oct 15, 2022Guru - Experienced User
This statement makes me a little leary.
"I am trying to set up my Nighthawk RAX38v2 as an access point. I was using it as my main router, but the upload bufferbloat was killing our network, so I bought an IQRouterv3, which is installed after a bridged Windstream Actiontec AC1900 modem/router."
Reason why is your going
modem/router---->router--->AP
and you were having bufferbloat before switching to another router.
Many times I find the modem/router combo devices "bridge" mode to not function properly.
It makes me suspicious that that Actiontec either isn't running properly in bridge mode or isn't in bridge mode and thats causing the bufferbloat.
What happens if you put the actiontec back in router mode (disable its wifi) and put the RAX in AP mode and connect it to the actiontec? You might not need the iqrouter at all.
