NMLiz
Oct 14, 2022Guide
Setting up RAX38v2 as an access point
I am trying to set up my Nighthawk RAX38v2 as an access point. I was using it as my main router, but the upload bufferbloat was killing our network, so I bought an IQRouterv3, which is installed afte...
NMLiz
Oct 16, 2022Guide
Apologies, I had not set up a static IP on the IQRouter for the printer. Once I did so, it seems to be working correctly.
I was unaware that there were problems with bridge mode in the Actiontec. I was having problems with the previous Actiontec modem/router, so this is a brand new one that Windstream sent me. It seems to be working much better.
But thanks everyone for your help. If I start having problems again, I will try the Actiontec in router mode.
Oct 17, 2022Guru - Experienced User
Hope it works well for you with how you have it setup!
