Cevans81466
Dec 20, 2023Aspirant
Setting up two WAPs (RAX35s) on an RAX50
Ran into a snag when setting up my home network. Thought I could extend my network coverage by setting up two access points on the RAX50 router (using 2 RAX35s). Was able to set up one of the RAX35s b...
microchip8
Dec 20, 2023Master
I doubt the switch will make a difference.
Cevans81466
That’s my fear but the tech support person indicated this would likely be the solution. She also told me that the RAX50 can only support one WAP connected to it (not sure why that is). And then as I said she stated a switch would likely remedy this issue
