Messica_Jurphy's avatar
Apr 08, 2021
Setting up wifi channels/BGN?
Nighthawk Mesh MR60 (2 x satellites)
So I am VERY technologically impaired and need help to change settings in my router a mid satellites to support my Sonos sound system.
I’ve be asked by Sonos to do the following, but have no idea where to start or how to do this. Help?
- mode set to 802.11 BGN
- client isolation off
- manual wifi channels
- security to WPA2 w/ AES encryption
- enable UPNP
- all nodes on same channel
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Messica_Jurphy,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
